Inventor Forum
How to constrain polygon in square?
3 REPLIES 3
WHolzwarth
759 Views, 3 Replies
Until now I didn't find a way. The tree edges of the polygon should be moving along the edges of the internal square hole.
😉 Perhaps another task for JD's students. Files are 2014, but STEP can be made easily.
Walter
Walter Holzwarth
3 REPLIES 3
WHolzwarth
in reply to: WHolzwarth
Seems not so easy. Only two points out of three can move along the square at the same time. If one of them crosses a symmetry plane of the square, then the other one needs to loose contact, and the free point begins to move on the square's edge.
Walter Holzwarth
admaiora
Is this the movement you intend?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
WHolzwarth
in reply to: admaiora
Not quite like that, but similar. Meanwhile I got it. Movement can be done from 0 to 1080 deg for angle Drive
Thanks for looking, admaiora.
Walter Holzwarth
