The harness assembly MUST be created in the top level assembly.
Step1-create your harness file and save it.
Step2-Drop all connectors into your model and then drag them into the harness assy in the model browser.
Step3-constrain all your end connectors to existing geometry from the top level assy.
Step4-Add wires/segments,etc.. and route as needed.
Now if you need to use this harness in another top level assembly that is fine "AS LONG AS" all your connectors,etc..are in the exact place as the top level assy you modeled the harness in. Any change in connector position and its essentially start over from step1 again..
My biggest problem with cable/harness is that you cannot create the harness outside of the top level assembly (and set max length on each wire) and then move the segments around in the top level and its routing information is maintained in the top level assy file.. For example let say I want to model a harness for a hard drive to mother board connection that will be used in multiple computer cases with different locations for the harddrive and mother board. I would like to be able to create a new harness (outside of any other assembly) and add my 2 end connectors and create the ribbon cable and I set its max length as 12"..I want to be able to drop that same harness into 50 different assemblies and move the position of the end connectors around and only get an error when I have exceeded that 12" max length..But all ribbon cable routing would be maintained in the top level assembly so that I can simply have 1 harness file and the top level assembly remembers its routing so that another top level assembly can have the exact same harness assy file but routed in many different configurations.. (sure would be nice and a HUGE..HUGE improvement over the existing workflows)
Edited by: mcgyvr on Feb 2, 2009 12:43 PM
