From the picture, there are many files/part but those parts are in seprated folder. Now i want to compile all these files into 1 particular folder.
currently i'm browsing through each part's properties to find the directory of the files. then copy paste each files into the particular folder i want.
is there a better way to do this?
Solved by BLHDrafting. Go to Solution.
Are you using Vault?
Nope. i'm not using vault and i'm not familiar with it too.
Does this mean, i have to do it manually? 😞
Vault allows you to get all files, even those from different locations, and put them into a local folder other than the project folder.
Try Inventor (File)/Save As/Pack and Go. See the below graphic.
