Inventor Forum
How to combine rotate and turn on wheels
4 REPLIES 4
InventorInSchool
625 Views, 4 Replies
I've managed to get my wheels to rotate, but how can I get them to turn in the same direction as the box when it starts to move sidewise? ? I tried to create an angle with the origin of Part 1(Assembly 2:2) and the "golv", but it interfeared with other constraints.
4 REPLIES 4
Simon,
I took a look at you model and in Assembly 2 you need to ground Part33.
After that you need to suppress Angle 5.
You will need to suppress the angle for each of the caster sub-assemblies.
On a side not I noticed that your files were all created with Inventor 2013 RTM.
You might want to let your instructor and IT know that there are service packs and updates.
I hope that this helps.
Bob Holland
Autodesk Product Support
It still says that I'm unable to animate. "Model has failed to update for the current time. Please correct the animation definition."
Anyone?
Why is it that you only can get one answer per thread?......... Smiley Sad
