So, I'm wondering how I can combine the bend function & flange in an animation. The problem is that I'm unable to use flange when the plate is nearly 98% flat (which I need to remain the radius for favorite parameters - bend function).
This seems to be a popular question around here lately.
http://forums.autodesk.com/t5/Inventor-General/flange-motion/td-p/4526905
Seems like it also came up here by another student about a month ago (looks to be exactly the same part?).
If you can't figure it out - attach your file here.
I figured that people would start to find it annoying if I threw in 30 questions in the same thread. How ever, do you find my question confusing? Bending > flanges the ends > and then error occurs when I decrease the radius.
I'll attach the Assemly tomorrow.
Thanks.
How can I animate the radius from 40mm to 0.8mm and still keep it horizontal? I cannot set any dimensions for height and width without to get error.
I don't get what you're up to with this sketch. What are those two floating lines for? You have a bunch of repeated and unrealistic dimensions. You're probably getting an error because those .5mm dimensions wont allow for a 40mm radius. The geometery would be mathimatically invalid.
The sketch is not the problem. created a new one, without all the dimensions that was unnecessary, to convice you.
Check out this attachment (the animation) and you'll see what the actual problem is.
I see what you're talking about now. But, that's just plain strange.
Anyways, I made this version using a surface extrusion, a thicken, and some bends. Does this work for you?
Thanks alot! I recreated all the steps in a new file and It now works prefectly fine.
