Inventor Forum
How to Coil a Coil
4 REPLIES 4
sohmoh
573 Views, 4 Replies
How to Coil a Coil
I have a question, can we coil a coil in nventor?
If I have a coil or spring, the I want to coil that coil/spring around another axies, can I??
I use Inv.2012
Thank you in advance
Tags (1)
4 REPLIES 4
SBix26
in reply to: sohmoh
Search this forum.  There have been a number of threads over the last several years dealing with this problem.  I'd try using the Bend tool, I think.  I'm not sure whether you can bend more than 360°, though.  But be aware that this is going to be a resource hog-- helices are really math-intensive.  If you don't need a functional model, you might consider using a textured appearance instead, kind of like the cosmetic threads that Inventor uses on screws.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
sohmoh
in reply to: SBix26
Well, Thank you for your quick response
But I tried the Bend comand, it could not help me.
Thank you again for your time sir.
JDMather
in reply to: sohmoh
A better way is with an Excel formula of points to generate a sweep curve.
In Inventor 2013 you can enter the formula directly (unfortunately I don't know it by heart - a search should return the forumla to use).
sohmoh
in reply to: JDMather
Thank you for your replay Smiley Happy
