Inventor General Discussion
Distinguished Contributor
10 Kudos
Post 1 of 13
How to check which assemblies a part file references
207 Views, 12 Replies
02-04-2013 05:47 AM
I was wondering is there is a way to select an Inventor part file and see which assembly file or files that is is currently used in ? It would be extremely useful to be able to see a list of all the assembly files which are using one particular part so when modifying the part you would know which assemblies would change.
Product Design Suite Ultimate 2013
64-bit HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
Distinguished Mentor
202 Kudos
Post 2 of 13
Re: How to check which assemblies a part file references
02-04-2013 05:52 AM in reply to: Anthony
Vault would be the best way to do that.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
10 Kudos
Post 3 of 13
02-04-2013 05:56 AM in reply to: mpatchus
Thank you very much for the reply, I'm sorry I forgot to mention I do not currently use Vault, I was wondering if there was a way to do this for non-Vault users ? Thanks
202 Kudos
Post 4 of 13
02-04-2013 05:57 AM in reply to: Anthony
I don't know of any way to do it without using Vault.
Mike Patchus
10 Kudos
Post 5 of 13
02-04-2013 05:59 AM in reply to: mpatchus
OK thanks, I guess Vault is the way forward then :smileyhappy:
130 Kudos
Post 6 of 13
02-04-2013 06:32 AM in reply to: Anthony
In Design Assistant/Tools/Find/Where Used
You can use this. Beware
Only use this on Small Folder sturcture. If you scan a large folder sturcture it will take a week to find files.
I don't use it, But it's there to use.
Douglas DuPont
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
10 Kudos
Post 7 of 13
02-04-2013 06:38 AM in reply to: Doug_DuPont
Thanks, could you post a screen shot of where this option is, I can't seem to find the 'where used' option is ?
202 Kudos
Post 8 of 13
02-04-2013 06:46 AM in reply to: Anthony
Like Doug said, be real careful where you use this, it literally could take days to run.
Mike Patchus
10 Kudos
Post 9 of 13
02-04-2013 06:50 AM in reply to: mpatchus
Much appreciated. :smileyhappy:
10 Kudos
Post 10 of 13
02-04-2013 07:12 AM in reply to: mpatchus
I am having trouble displaying the results from the search, it tells me 2 files found but does not display the details of the locations of the files etc. Please can you tell me how to do this ? (Screen shot attached)
