Inventor Forum
How to check which assemblies a part file references
12 REPLIES 12
Message 1 of 13
Anthony
1392 Views, 12 Replies
I was wondering is there is a way to select an Inventor part file and see which assembly file or files that is is currently used in ? It would be extremely useful to be able to see a list of all the assembly files which are using one particular part so when modifying the part you would know which assemblies would change.
Product Design Suite Ultimate 2013
64-bit HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12 REPLIES 12
Message 2 of 13
mpatchus
in reply to: Anthony
Vault would be the best way to do that.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 13
Anthony
in reply to: mpatchus
Thank you very much for the reply, I'm sorry I forgot to mention I do not currently use Vault, I was wondering if there was a way to do this for non-Vault users ? Thanks
Message 4 of 13
mpatchus
I don't know of any way to do it without using Vault.
Inventor 2025 Beta
Message 5 of 13
Anthony
OK thanks, I guess Vault is the way forward then Smiley Happy
Message 6 of 13
Doug_DuPont
In Design Assistant/Tools/Find/Where Used
You can use this. Beware
Only use this on Small Folder sturcture. If you scan a large folder sturcture it will take a week to find files.
I don't use it, But it's there to use.
Douglas DuPont
Inventor 2016 Pro, Vault 2016 Pro
Quadro M4000
Windows 10 64 Bit
Message 7 of 13
Anthony
in reply to: Doug_DuPont
Thanks, could you post a screen shot of where this option is, I can't seem to find the 'where used' option is ?
Message 8 of 13
mpatchus
Like Doug said, be real careful where you use this, it literally could take days to run.
Inventor 2025 Beta
Message 9 of 13
Anthony
Much appreciated. Smiley Happy
Message 10 of 13
Anthony
I am having trouble displaying the results from the search, it tells me 2 files found but does not display the details of the locations of the files etc. Please can you tell me how to do this ? (Screen shot attached)
Message 11 of 13
mpatchus
It probably found a file of the type you did not have checked off.
Inventor 2025 Beta
Message 12 of 13
Anthony
Please could you explian ? Thanks
Message 13 of 13
mpatchus
Not sure why it would show 2 files, but not list them in the bottom window.
Inventor 2025 Beta
