Inventor Forum
How to change the width of sprocket generated by Design Acc
2 REPLIES 2
alex2012us
302 Views, 2 Replies
Hello guys, I'm using Design Acc to generate sprockets, but I didn't find any option which I can change the width of sprockets, I remember in gear generator, I can change the gear width, does anybody know how to change sprockets width?
2 REPLIES 2
JDMather
in reply to: alex2012us
The width of a sprocket is determined be the chain size - you cannot arbitrarily set it to any width?
If you want to change the chain specification to a wider chain - simply right click on the DA sub-assembly node in the browser and select Edit with Design Accelerator (or something like that).
If you want to edit the hub - simple edit the ipt file.
alex2012us
in reply to: JDMather
Thanks, JD, I got it~! I'll change the chain size instead
