We are trying to change the UCS coordinate in assembly. But we cant change it.
Please let us know the solution.
Tushar
Can you unground the grounded component and re-mate to the origin workplanes?
Or do you simply want to change the Top of Front view designation (set to desired orientation and right click on the view cube to reset).
Tushar,
Take a look at this thread and see if it helps you.
http://forums.autodesk.com/t5/Inventor-General/change-part-coordinate-system/td-p/2966208
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
