Inventor Forum
How to change the section direction
4 REPLIES 4
Karol-Or
8654 Views, 4 Replies
In an assembly, i make a half section view, but i want the other side to be seen.
I want only to change the direction of the view, how can i do that?
4 REPLIES 4
cbenner
in reply to: Karol-Or
Redefine the section view and while you have the "pull" arrow on the screen, right click and select "Flip Direction".  Looks like once the view is created, redefining it is the only way to flip the direction.  Unless someone else sees something I don't?
BLHDrafting
The side cut away is always the side closest to that you are viewing it from. Try it out for yourself based on the same plane. Rotate your assy between sectiosn and see that the above is correct.
Interestilgly if you view the assy from the side of the plane (so the plane is just a thin lin), regardless of why way the model is orientated it always cuts away the same side. Interesting, but largely useless info Smiley Happy
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
BLHDrafting
in reply to: BLHDrafting
Note to self :- must read typing before posting to limit how much of a tool I am. Spelling and punctuation, my english teacher will be turning in her grave. Smiley Frustrated
Brendan Henderson
EgraphNo1
Right click the section line itself and select "Reverse Direction".
