Welcome.
I have Polish version of Autodesk Inventor 2013 Profesional.
Tooltips display ribbons to me in English.
How do I set to display them in the Polish language?
Thank you in advance for your help.
Did you download and install the language package?
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18550979&linkID=9242019
I tried.
I can not install the Polish version because that is already installed.
So he sees the system.
It could be a bug, are you on the current SP 1.1?
SP 1.1 is installed.
I did a test. I have uninstalled all the patches and service packs.
The error is still there.
Once installed SP 1.1.
I hope that someone from Autodesk looks at this thread, it must be a bug. Check with your reseller or if you are on support, log a support call.
Recently swapped the files in the Templates folder to the new and the problem disappeared. Tooltips have the correct language.Unfortunately, only for a moment. After a few days I have tooltips again in another language. It will give it to someone can answer why this is happening.
This could also be connected to your keyboard language settings with in Windows see the attached.
Unfortunately, it's not. Language settings are fine. The error must be somewhere else.
Where are the files Tooltips?
Maybe something manually swapping files help?
I found only the files to Fusion.
They are in the directory:
C:\Program Files\Autodesk\Inventor Fusion 2013\pl-PL\Configuration\ToolTips
However, I can not find the files to Invetor.
