Hello
I wish my Material will have the certain assigned Color.
For instance in the 2012 I have a Steel and assigned Steel Colour.
Once I change the properties of Steel Colour and save them to Library I will have
all further new Steel parts to be represented with this altered Colour by default.
How to make this simplest trick in the 2014?
I cannot stand any glossiness and reflectivity came with appearances and I wish I could
get rid of that. I still work on 2012 exclusively because of appearances.
Best regards,
Orest Yavtushenko
Hey there. I attached a picture of the steps
First go to your project management, and make sure your project has read-write access to the style library, as show on the first part. You right click in order to change that!
Then open a part file and go to the material browser which is marked with red. Double click the material you would like to edit, and go to appearance.
Choose whatever appearance you would like. You can right click the appearance tab and choose "replace", and then choose an appearance you made yourself.
After that, you can go to manage, and press "Save" as shown - That should update the material in your style library.
Now that it's saved in your style library you may need to go to manage and press "update" on the files that need updating (There probably is a smarter way to do it, if you have a lot of files)
Hope this helps
Best regards
Yannick Nielsen
here is a link to an interesting post of our "Being Inventive" blog dedicated to Inventor:
An additional link to a pdf document explaining in detail the migration process from 2012 to 2013 or 2014 version:
I hope that will help
Best Regards
I managed to change the color and save to existing library somehow.
That is all I did so far. The 2012 and previous Styles were a bit complicated but clear and simple. Especially regarding making own materials and colors. The appereances seems like big and weird headache...
Orest
