Inventor General Discussion
0 Kudos
Post 1 of 9
How to change size of project?
175 Views, 8 Replies
07-16-2013 04:52 AM
I created 3 parts, which I shell use in my presentation. But when I put they near, I saw that they have big changes in size. How can I correct this without making new projects?
0 Kudos
Post 2 of 9
Re: How to change size of project?
07-16-2013 04:55 AM in reply to: vlad.kuzik.95
Here it is
*Expert Elite*
2,120 Kudos
Post 3 of 9
07-16-2013 04:56 AM in reply to: vlad.kuzik.95
Attach the files here.
Did you use the same units (inch or mm) for all files?
You can edit the files to change sizes of features.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
0 Kudos
Post 4 of 9
07-16-2013 04:58 AM in reply to: JDMather
0 Kudos
Post 5 of 9
07-16-2013 04:59 AM in reply to: vlad.kuzik.95
0 Kudos
Post 6 of 9
*Expert Elite*
2,120 Kudos
Post 7 of 9
07-16-2013 05:06 AM in reply to: vlad.kuzik.95
In your part I didn't see any dimensions.
Parts must have dimensions to be manufactured.
The current units were set to inch and the actual size (if dimensioned) is tiny.
0 Kudos
Post 8 of 9
07-16-2013 10:45 PM in reply to: JDMather
So, what I should do?
*Expert Elite*
2,120 Kudos
Post 9 of 9
07-17-2013 04:37 AM in reply to: vlad.kuzik.95
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Post to the Community
New Post
