I created 3 parts, which I shell use in my presentation. But when I put they near, I saw that they have big changes in size. How can I correct this without making new projects?
Attach the files here.
Did you use the same units (inch or mm) for all files?
You can edit the files to change sizes of features.
In your part I didn't see any dimensions.
Parts must have dimensions to be manufactured.
The current units were set to inch and the actual size (if dimensioned) is tiny.
@Anonymous wrote:So, what I should do?
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inventor
