Is there a way to change or control the color of sketch objects? I didn't see any way to set colors for sketch objects within the Application Options. Might there be some registry entries that could change the color of sketch objects?
Sometimes it's useful to be able to use colors other than Green and Black for sketch objects.
Any tips, suggestions or errata would be appreciated!
Solved by harco. Go to Solution.
Thanks Harco for the quick reply! Will your proceedure work with Inventor 2010?
This help doc is dated 2010 so possibly it will work.
