How to change memory which uses inventor ? I have 3 GB but use 2GB.
Solved by rgruychev. Go to Solution.
Solved by mcgyvr. Go to Solution.
Turn on the 3G switch (google will tell you how).
Better choice is the upgrade to Windows 7 64 bit.
Important: Autodesk does not support or endorse the /3GB switch. In many cases, this customization will cause Inventor graphics to be incorrectly displayed. Instead, we recommend updating to a 64-bit version of Windows.
DarrenP
