Inventor Forum
How to change G_L parameter from decimal to fraction
10 REPLIES 10
Message 1 of 11
2816 Views, 10 Replies
Can anyone point me in the right direction as to how to change the G_L parameter from decimal to fraction (1/16)? I've attached some screnshots.
10 REPLIES 10
Message 2 of 11
pierre.masson
Hello Crepps
By going in the part itself, clicking in the parameters, Customer Parameter G_L.
If you right click in the value field, Custom Parameter properties. Then you can set the value to fractional.
Going back in the assembly, if you go in the BOM, add custom Iproperty G_L
Is it fine like this ? Was it helpful ?
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
Message 3 of 11
What if I have a frame generated part that has 100 members in it. Is there a quicker way of changing G_L to a fraction so that I don't have to go into all 100 parts to change the custom properties?
Message 4 of 11
jtylerbc
You can make a custom family in the Content Center, where you've replaced the family part template with one that has the property set to fractional.  I have that set up in mine for all of the structural members I commonly use.
However, that doesn't help you with a frame that's already built.  It would only prevent the problem you're having now from getting you again.  I don't know of a way to do it quickly after the fact.
Message 5 of 11
pierre.masson
in reply to: jtylerbc
Sorry for the late reply. I wrote a piece of Code to automate the Unit Change in the BOM parameter.
This is based on Bob Van der Donk's Code.
We scan all the occurences of the Assembly, if it is a Frame member, we change the unit of G_L to in and change the precision to 1/8. I had to us the precision change to force the switch to fractional. You can easily use another precision value as long as it is a fractional one.
Please test the code before pushing this to production.
Please Kudo if you like so others will see it.
Option Explicit
Public Sub Correct_G_L_parameter()
        ' Set reference to active document.
        ' This assumes the active document is an assembly
        Dim odoc As Inventor.AssemblyDocument
        Set odoc = ThisApplication.ActiveDocument
        ' Get assembly component definition
        Dim oCompDef As Inventor.ComponentDefinition
        Set oCompDef = odoc.ComponentDefinition
        Dim sMsg As String
        Dim iLeafNodes As Long
        Dim iSubAssemblies As Long
        ' Get all occurrences from component definition for Assembly document
        Dim oCompOcc As ComponentOccurrence
        For Each oCompOcc In oCompDef.Occurrences
            ' Check if it's child occurrence (leaf node)
            If oCompOcc.SubOccurrences.Count = 0 Then
                iLeafNodes = iLeafNodes + 1
                Call Assign_ref_to_G_L(oCompOcc)
            Else
                iSubAssemblies = iSubAssemblies + 1
                Call processAllSubOcc(oCompOcc, _
                                    sMsg, _
                                    iLeafNodes, _
                                    iSubAssemblies) ' subassembly
            End If
        Next
        odoc.Update
        'Save the assembly
        'odoc.Save
    End Sub
    ' This function is called for processing sub assembly.  It is called recursively
    ' to iterate through the entire assembly tree.
    Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence, _
                                 ByRef sMsg As String, _
                                 ByRef iLeafNodes As Long, _
                                 ByRef iSubAssemblies As Long)
        Dim oSubCompOcc As ComponentOccurrence
        For Each oSubCompOcc In oCompOcc.SubOccurrences
            If oSubCompOcc.SubOccurrences.Count = 0 Then
                Call Assign_ref_to_G_L(oSubCompOcc)
            Else
                sMsg = sMsg + oSubCompOcc.Name + vbCr
                Call processAllSubOcc(oSubCompOcc, _
                                      sMsg, _
                                      iLeafNodes, _
                                      iSubAssemblies)
            End If
        Next
    End Sub
    Private Sub Assign_ref_to_G_L(ByRef oCompOcc As ComponentOccurrence)
        Dim odoc As Object
        Dim oparams As Parameters
        Dim oparam As Parameter
        Set odoc = oCompOcc.Definition.Document
        Set oparams = odoc.ComponentDefinition.Parameters
        'Check if it is a part document and if it is not read-only and if it is a framegenerator beam
        If (TypeOf odoc Is PartDocument) And (odoc.IsModifiable) And (odoc.DocumentInterests.hasinterest("{AC211AE0-A7A5-4589-916D-81C529DA6D17}")) Then
            For Each oparam In oparams.UserParameters
                ' Find the G_L parameter and make sure at least a reference parameter exists in the beam
                If oparam.Name = "G_L" And oparams.ReferenceParameters.Count > 0 Then
                    If oparam.CustomPropertyFormat.Units <> "in" Then
                    oparam.CustomPropertyFormat.Units = "in"
                  End If
                  If oparam.CustomPropertyFormat.Precision <> 85517 Then
                  oparam.CustomPropertyFormat.Precision = 85517
                  End If
        End If
        Next oparam
        End If
    End Sub
Message 6 of 11
Vitornis
in reply to: pierre.masson
How do you set the precision to 1/16"
Message 7 of 11
SPPatil
My self also facing same problem,
I do not need unit string appear in BOM. also how to load listed code in inventor...
Thanks & Regards,
SP
Message 8 of 11
SPPatil
Hi John,
How to make a custom family in the Content Center?
I am also facing same problem...
Please Help...
Thanks & Regards,
SP
Message 9 of 11
SPPatil
Hello Pierre Masson,
Thanks for useful information, but,
What about already generated frame, by going 100 or more parts to change the same it is time consuming job.
is there any other idea that can help us change the parameters...
Thanks & Regards,
SP
Message 10 of 11
pierre.masson
in reply to: SPPatil
Can you put all your frame generator parts in C:\Temp folder. Then run this code that will open all IPTs from this folder and make the modification.
This code might require some slights adjustments.
Sub ChangeBOMUnit()
On Error GoTo Getout
Dim opart As PartDocument
ThisApplication.SilentOperation = True
 Dim colFiles As New Collection
    RecursiveDir colFiles, "C:\Temp", "*.ipt", True
    Dim vFile As Variant
    For Each vFile In colFiles
         Set odrawing = ThisApplication.Documents.Open(vFile)
         Call Assign_ref_to_G_L(opart)
         opart.Save
         opart.Close
    Next vFile
Getout:
ThisApplication.SilentOperation = False
End Sub
Public Function RecursiveDir(colFiles As Collection, _
                             strFolder As String, _
                             strFileSpec As String, _
                             bIncludeSubfolders As Boolean)
    Dim strTemp As String
    Dim colFolders As New Collection
    Dim vFolderName As Variant
    'Add files in strFolder matching strFileSpec to colFiles
    strFolder = TrailingSlash(strFolder)
    strTemp = Dir(strFolder & strFileSpec)
    Do While strTemp <> vbNullString
        colFiles.Add strFolder & strTemp
        strTemp = Dir
    Loop
    If bIncludeSubfolders Then
        'Fill colFolders with list of subdirectories of strFolder
        strTemp = Dir(strFolder, vbDirectory)
            If (strTemp <> ".") And (strTemp <> "..") And (strTemp <> "OldVersions") Then
                If (GetAttr(strFolder & strTemp) And vbDirectory) <> 0 Then
                    colFolders.Add strTemp
                End If
            End If
            strTemp = Dir
        Loop
        'Call RecursiveDir for each subfolder in colFolders
        For Each vFolderName In colFolders
            Call RecursiveDir(colFiles, strFolder & vFolderName, strFileSpec, True)
        Next vFolderName
    End If
End Function
Public Function TrailingSlash(strFolder As String) As String
    If Len(strFolder) > 0 Then
        If Right(strFolder, 1) = "\" Then
            TrailingSlash = strFolder
        Else
            TrailingSlash = strFolder & "\"
        End If
    End If
End Function
Private Sub Assign_ref_to_G_L(ByRef odoc As Partdocument)
                  End If
                  End If
        End If
        Next oparam
        End If
    End Sub
End Sub
Message 11 of 11
Genicee
in reply to: Vitornis
In 'Assign_ref_to_G_L' sub change 85517 to 85518.
