how to change default units to metric for inventor2013? Now I have them set as imperial.
thanks and regards
Jis
Solved by SBix26. Go to Solution.
You can select units by using special templates, whe setting up a new file.
By default here with a German version, the template is called Norm.ipt and is in millimeters. And there are subfolders, too, for English or Metric setup.
Walter
Walter Holzwarth
I'm not sure if you're asking about changing a single file, or about changing templates?
To change a single existing part or assembly file, open Tools tab > Document Settings > Units tab and change units as you please. To change a single drawing, you will probably need to create some metric styles.
To change to metric templates as installed, Application Options > File > Configure Default Template... button.
Thank you very much! I had this same question and your answer was so simple and precise. Thanks for the support.
Attach your file here.
If you modeled using magnitude with incorrect units - changing the units isn't going fix the part.
ex, 1 inch become 25.4 mm not 1 mm
