Inventor Forum
How to bend a sheet ...
9 REPLIES 9
Message 1 of 10
ssymurali
563 Views, 9 Replies
Hi all can any one of u tell me how to bend a sheet to make a cylinder (In Sheet metal)...Regards, Murali
9 REPLIES 9
Message 2 of 10
in reply to: ssymurali
Start new "standard.ipt" part.
Revolve a profile 359 deg around an axis.
Select sheet metal under tab
applications.
Set sheet metal thickness same as profile
thickness
Before you select "flat pattern" select inner face
of tube.
Christian
Hi
Message 3 of 10
Or start with the flat pattern and use the fold command.
Richard
> Select sheet metal under tab applications.
> Set sheet metal thickness same as profile thickness.
> Before you select "flat pattern" select inner face of tube.
> Christian
Message 4 of 10
Use the Contour flange command
See my example file in CF
hope this is what you wanted
Message 5 of 10
ssymurali
Niemarkt thanks for ur response ...u suggested me to start with new "standard ipt" but i have to perform in "sheet metal ipt"
Message 6 of 10
You can also start with "sheet metal.ipt". If
you want to revolve the profile just switch to "part features" and when youre
fineshed switch back to "sheet metal features".
Niemarkt
Message 7 of 10
ssymurali
thanks zico but what is CF u r telling about...
Message 8 of 10
"Inventor Customer Files"
Its where you can upload files
http://discussion.autodesk.com/WebX?14@@.f15ad3a
Message 9 of 10
What kind of file did you post?  The one in
iCF is named "filename=.dat".  I tried changing the extension to .ipt, but
it would not open in Inventor 7.
Use
hope this is what
you wanted
Message 10 of 10
Try changing it to Anything.Zip
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Kirk A." wrote in message
news:BDD5DC1CC07ECE19F5711AFE7CEDE694@in.WebX.maYIadrTaRb...
> What kind of file did you post? The one in iCF is named "filename=.dat". I tried
changing the extension to .ipt, but it would not open in Inventor 7.
> "zico" wrote in message
news:f197ddd.2@WebX.maYIadrTaRb...
