Inventor General Discussion
Active Member
Les LaZar
Message 1 of 7 (1,431 Views)
How to align parts in assembly?
1431 Views, 6 Replies
09-22-2005 11:07 PM
I have a real noobie question. I've been using AutoCAD since V1.2. I recently obtained Inventor 10 and I am in the process of learning to use it.
I must be missing something obvious regarding the alignment of parts in the assembly module. For example: I have two parts defined...a flat plate, 12" x 12" x .1" and an angle bracket, 6"L x 2" x 2" x .1 thick. The plate is the base part. Now I want to place the bracket on the plate in a precise position and orientation....say the corner of the bracket is 1" in x and y from the corner of the plate.
I've been struggling with this for several days. In AutoCAD I would have used a couple of offset commands to establish the corner point at 1,1 from the corner of the plate and then moved the bracket to that point using object snaps.
In IV10, I can drop back to sketch mode and add the guide lines to the surface of the plate but I haven't found any way to EXACTLY place the bracket at that intersection. Nor can I find an "easy" way to orient the bracket precisely with respect to the surface of the plate (regardless of location). The MATE constraint is usable for aligning the top surface of the plate to the bottom surface of the bracket, but the bracket is often rotated, at least a bit, with respect to the edges of the plate. Can someone please give me a clue as to what I am missing?
Thanks for an assistance,
Les
*Rui Vaz
Message 2 of 7 (1,431 Views)
Re: How to align parts in assembly?
09-23-2005 12:38 AM in reply to: Les LaZar
First off, maybe some reading of the GETTING STARTED would be the least
to do to, well, get started.
The process is explained there.
Start an assembly and assemble your base part
Assemble the other part. Now, you can choose appropriate constraints to
ALIGN or MATE surfaces and planes (with or without offsets) to position
your parts.
Let me know your e-mail and I'll send you a better quality movie. It's
3.2MB so I don't think I can post it here.
HIH
Rui
> Les
*Duncan Anderson
Message 3 of 7 (1,431 Views)
09-23-2005 01:23 AM in reply to: Les LaZar
Here's one I did earlier.
Sometimes it's easier to play with something done by somebody else to get you over a hurdle
But don't rely on others doing everything else for you.
HTH
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad
as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
wrote in message news:4965061@discussion.autodesk.com...
learning to use it.
Les
*Hal Gwin
Message 4 of 7 (1,431 Views)
09-23-2005 08:13 AM in reply to: Les LaZar
Check out the Visual Syllabus on the top menu bar, second icon from the
right. These are mini visual tutorials, should help you out with most
basic questions.
> Les
Hal Gwin
Mechanical Designer
Xenogen
R9 Pro SP2
XP Pro SP2
Dell Precision 650
Dual 2.66 GHz Xeon
3 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.7718 w/registry update
Dell UltraSharp 19" LCD
Active Member
Les LaZar
Message 5 of 7 (1,431 Views)
09-23-2005 06:01 PM in reply to: Les LaZar
Rul,
Thanks for the response. I RE-READ Chapter 7 of the Inventor Getting Started manual, but I still didn't see what I needed.
Please send your movie to: "les+lazar at pacbell dot net" and delete the plus-sign.
Les
Active Member
Les LaZar
Message 6 of 7 (1,431 Views)
09-23-2005 06:04 PM in reply to: Les LaZar
Duncan,
Thanks for the file. I will examine it and let you know if it helped.
Les
Active Member
Les LaZar
Message 7 of 7 (1,431 Views)
09-23-2005 06:05 PM in reply to: Les LaZar
Hal,
Thanks for the pointer. I thought I looked at all of those tutorials when I first installed the software, but I will take another look.
Les
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
