Hi All,
I'm trying to place an aligned dimension as per the attached sketch. I'm looking to get the dimensions align with red line but can't get it to work and I'm sure there must be a way because it is a fairly common type of dimension.
Any help would be gratefully appreciated.
regards
Hi Paul,
It's not possible just like that, you have to be a little inventive.
Put a sketch on top of your view and project some lines. Then draw 2 "sketch only" lines. Like I putted in orange in the attachment.
Then dimension the line like you indicated with the blue dimension.
Finish the sketch.
Click with RMB on the sketch and select "retrieve dimensions" and select the dimension to get it from the sketch to your view.
That does the trick, and it should als be adaptive if you change something to the model 😉
So the trick here is...put it in a sketch and get the dimension from it...
Hi Stefaan,
Thank you for posting your solution. I will use that for the time being however I must say I'm surprised that Autodesk hasn't programed this type of dimensioning in Inventor as it is a very common type of dimensioning. Moreover it was always a standard feature in AutoCad so as I say I am very surprised as to why it's not included as a standard command in Inventor.
I would be interested to hear from anyone from AutoDesk on this topic as to why it isn't included. I recently completed the drawing survey and this certainly would have been something I would have commented on.
Hi Quadratec,
You might take a moment to share your ideas about how to improve Inventor with the Development Team on the IdeaStation:
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
I hope this helps.
Curtis
Hi Curtis.
There is already an idea for this:
