Inventor Forum
How to add material thickness to a face?
5 REPLIES 5
WAYNE_HOUWD
1955 Views, 5 Replies
Hi all,
How can I add a material thickness to a face trimmed from IGES file?
I have a surface imported from IGES file, then trimmed to a single face in IV that I would like to materialize.
I tried times for thickness, but IV doesn't like it.
Neither can I apply Shell for part, nor thickness adding from Sheet metal.
It is a 3D Lofted surface, very simple single one.
Any thoughts, please advise.
Best Regards,
Wayne
5 REPLIES 5
JDMather
in reply to: WAYNE_HOUWD
Thicken/Offset
 (how would Shell give you thickness of a surface?)
The CADWhisperer YouTube Channel
WAYNE_HOUWD
in reply to: JDMather
Thanks, Prof. JD.
WAYNE_HOUWD
Hi JD, how can I flatten this part ?
Wayne
JDMather
You didn't indicate the thickness of the material, but use the Sheet Metal Lofted Flange tool (see attached).
WAYNE_HOUWD
Thanks for the work on the demo part. Unfortuately, I am still using Inventor 2012. So the file you attached I cannot open.
By the way, we can assume the material is 12GA, 0.1046".
Thanks again, Prof. JD.
Wayne
