Inventor Forum
How to add custom attributes to existing materials
5 REPLIES 5
cristian.pena
449 Views, 5 Replies
Good morning, I want add some attributes as custom codes to the Inventors' existing materials, how to can I make it?
5 REPLIES 5
mcgyvr
in reply to: cristian.pena
Version of Inventor?
Assuming 2013 or newer just
Edit the material... add what you want to the "Identity" tab in one of the fields that isn't being used like comments or whatever.
cristian.pena
in reply to: mcgyvr
Good morning,
 i'm using Inventor 2014, also tried to use it, but i want add some field empty to use as custom field, for example Material Code or another Specs,
This is possible?
thanks,
Mario428
@cristian.pena wrote:
Good morning,
This is possible?
thanks,
Start up your Iproperties
Click on the "Custom" Tab in that window
put the name of your custom property in  the "Name' box
Set the variables and hit "Add"
In an IDW you will have to edit your BOM to make it show up
Double click the BOM
Click the leftmost Icon at the top of the BOM " Parts List Column Chooser"
Click on New Property, put your new property name in EXACTLY as you added it to your custom properties
Click "add" to make a BOM column and position it using the Up & down buttons.
It is now in your BOM
crystaltech
in reply to: Mario428
Hello All,
I’ve been looking to do this as well. Is there a way to link any of the Material Library attributes in the ‘Identity’ tab to iproperties? We need to have the material (Steel) separate from the Grade (44W).
Thoughts?
Mario428
in reply to: crystaltech
We have some Ilogic in our template that does this. But a couple of separate templates will do the same thing. One template for steel and another for 44W
@crystaltech wrote:
Hello All,
Thoughts?
