Inventor Forum
How to add a bump map to a texture
3 REPLIES 3
2454 Views, 3 Replies
Hi there i am workin on a model in inventor and i want it too look as good as possible, so one of the things that i need is to bump map a texture. Please help me.
I have a custom texture and a bump map file as well but where do i put it?
3 REPLIES 3
mflayler2
You do this in Inventor Studio. The bump map will not appear until you render it. Adjust Surface Styles as necessary to get to your goal.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
JDMather
>where do i put it?
You didn't mention what version of Inventor you are using.
You will also need to become familiar with the Styles Editor.
scottmoyse
u don't actually need a bump map if you don't want one. Well i know thats for sure in 2010. In studio under the texture styles you can check a box to use the color bitmap as the bump map as well.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
