I've got a component that I'd love to make an assy but I'd have to do so many cuts and copy objects It's pathetic. So what I've done is make a multibodied part and had those become parts of an assy. Whatever I can add to the part that doesn't need to be combined w/ the others I add to the newly created part. However I have trouble w/ the fact that seemingly at random I wind up w/ simple commands taking way too much time.
Ie. I create a new sketch and then try to draw a line, I have to wait for the computer to think for up to 30s. This seems to come and go.
I've got over 300 parameters, 10-15 solids, and probably 50 or so features (extrusions mainly).
I don't know if the slowness is a result of network issues or am I running afoul of an unwritten limit for complexity in a solid?
What I like to do is create the part in the same way using multiple solids to create multiple components. I find this easier then creating multiple parts in an assembly and jumping form part to part.
When I have the basic shape of the components I turn the visibility off until one part remains and save it as copied part.
I repeat this with all the solids until you’ve got your components separately in part files and add them to an assembly.
Then I add finer detail in the full assembly and I never really have performance issues
The number of solids you can have depends more on your computer spec then the software.
Hope this helps
That's basically the workflow I'm using except I use the "make components" command to form them into one assy. Then when the parts have been seperated I add finishing touches so as not to disturb the original part. I'm basically making a room w/ lots of stiffeners joining up and then adding insulation. I'd use frame generator but for some reason our setup here makes that a major pain. The room isn't just a straight box w/ easy connections but w/ angled windows, custom trim and stuff. When all's said and done I'll have a part w/ 10-15 solids, mabye a thousand parameters and probably about 150 -200extrusions, sweeps, etc. I just wonder where's IV's limit because I keep having issues w/ basic simple inputs taking forever.
For complex models, complex mold assemblies, and large assemblies
So maybe some more RAM may help you with the performance issues. But the spec above should handle most things you throw at it
My guess is that there is an "error" somewhere that is causing the slow-down problem.
Have you done a "Rebuild All" recently to see if the model is still sound?
