Solved by dave.anderson. Go to Solution.
In some cases, the mini-toolbar does not offer all the options that the full dialog does. This is why you'll see both interfaces currently.
Here's a link to a post the Inventor Support blog that outlines how you can control the full dialog with an Environment variable:
http://beinginventive.typepad.com/being-inventive/2011/06/inventor-2012-expand-dialogs.html
I hope this helps.
Hello Dave,
Thank you for the info. You are right about it being incomplete. This is very irritating & makes me wonder why the devs would implement something that is incomplete. I can't use the mini because it is missing info so what is the point of it being there.
@Anonymous wrote:Hello Dave,
Autodesk loves to do that crap... Rush it to market half assed is the Autodesk way...I can't believe they still have dual dialogs in 2012 though.. I thought someone would have fixed that by now. I complained in beta (2010?) when they first did it and complain everyday I use inventor.. There are MANY times each day where having 2 dialogs causes me to have to do multiple clicks and write number multiple times because Inventor looses focus on one dialog box or the other.. Its total BULLSHI*.
I seriously can't believe a simple check box hasn't been incorporated into the application options to disable the new dialogs.
I wonder what is the point of having beta testers if they aren't going to listen to them? I see new features that are just remakes of existing features & don't fix a problem. It is very frustrating.
