Inventor Forum
How exciting!
10 REPLIES 10
Message 1 of 11
227 Views, 10 Replies
How exciting!
For 3rd time, I have rendered an animation and it got to around the 121st frame of 151 frames and then crashed. It took 3-1/2 hours to get to that point. How fun is that?
10 REPLIES 10
Message 2 of 11
probably ran out of RAM. You could try making animations around 100 frames long, then put them together with Windows Movie Maker (comes with XP).
Message 3 of 11
Do you have the 3GB switch in place? Were you getting the 80% resources error when you crashed?
I heard at AU that the memory usage is supposed to greatly improve in IV11.
Message 4 of 11
  1. Make sure you have the memory limit set to warn you when it is
    approaching 80%
  2. When Inventor tells you it has reached the limit, say OK
  3. Note the time / frame studio has rendered to
  4. Hit the red stop button in the render dialog.  This will cause
    the animation to be saved
  5. Close and reopen Inventor, reenter studio and change the start
    time for recording to match where it got to in the previous render
  6. Change the file name it will render to
  7. Restart the render animation
  8. Repeat as necessary
I have done a couple of animations that took in excess of 30 hours to
make.  I broke them up into pieces as described above and glued them
together.  Running /3GB is important for large animations.  As a rule,
if the assemblies load into much over 1GB of address space, you will
have to break up the rendering into pieces.  Consider lightening up the
assembly to get it to load in less than 1GB.  Many of the small parts
aren't going to be visible anyway so why have Inventor try to calculate
them.
Of course for the above to work, the video frames need to be EXACTLY
the same and the Cameras need to be set so the frames are shot from the
correct viewpoint.  I use a program called Sizer from
http://www.brianapps.net for sizing the windows.  It is handy for a lot
of other applications and is free.  Hint:  you will need to create a
new size in Sizer to get the correct window size for Inventor.  On my
computer,  to get a 640x480 animation, I set the Sizer window to 652x511
If you know by the first crash that it makes it for about 1/2 the
frames, then I would just break it up into 1/3rds and render out 3
pieces.  You can glue the clips together with a video program.  Several
have been described in other threads.  I use Camtasia.
Message 5 of 11
How do you make several animations and put them together?
Message 6 of 11
see the post from cbliss. Windows Movie Maker is a program that comes with Windows XP (I don't know which versions). You can render a set of small animations (.avi) then use Move Maker to put them all together and export a full length .avi.
Message 7 of 11
Some things you just need to talk to someone live. Is there a way I could talk to you by phone?
Message 8 of 11
I tried doing the animation as you suggested. When I got the 80% dialogue box message, I hit o.k. However, the box does not dissappear. So I expanded the box and selected show only once per session. This got rid of the box. Then I noted the time the animation got to. Now when I go to set up the next animation and tell it what time to start on, I get lost. The time it gave me that the last animation stopped at does not make sense. This animation has 151 frames to it. I got to 100 when I got the 80% message and ended the animation. The time it said was 2:18:35. What is that? Is that 2 seconds? Two what? It has to be longer than two seconds. The animation is a total of 10 seconds long!
Message 9 of 11
Since I use Camtasia, I just load up the clips and cut out the extra
frames. I don't know if other programs like Movie Maker support that
but I would think they should.
Since you know about how far you can get, just set up the length to
record to that time. For a 10 second animation, if you know you can
render 5 seconds before it gaggs, I would render 0-4 the 4 - 8 and
finally 8 -10 then join the 3 clips together. Make sure you save each
of the clips to a different file name. Inventor is pretty good about
just overwriting the previous clips with the new ones if you forget to
provide a different name.
Message 10 of 11
Send me a private email if you want.
Message 11 of 11
Got it! Thanks.
