Inventor Forum
How does the MITER command work?
6 REPLIES 6
elmotors
2237 Views, 6 Replies
I have four square bars to make a rectangular frame.  I was hoping the Miter command would chamfer the ends to make 45 degree miters.  When I click on Miter, I get the window but I cannot select any of the bars, either in the graphics window or in the browser.  The OK button is always greyed out (unselected).
Tags (2)
6 REPLIES 6
cbenner
in reply to: elmotors
Dumb question... was your frame built using the Frame Generator?
elmotors
in reply to: cbenner
No, never used FG.  Can you elaborate without adjectives?  Thanks.
blair
It is a specific tool for use within Frame-Gen. It pretty much does what you are looking for but is specific to the Frame Generator module. http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-DDC54112-F131-4612-AA0A-1264FB5E210F
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
johnsonshiue
It sounds like you want to use Frame Generator command on non-Frame members. But, I am not 100% sure without seeing the files. To avoid confusion, could you post the simple example here?
Thanks!
Software Test Engineer
elmotors
in reply to: johnsonshiue
Basically yes.  Since I got into this I have looked into Frame Generator and I can see how it would work.  I was trying to miter bars that I had created through extrusions.  Since I played with Frame Generator a bit, I have found that the sizes available (in this case square tubing) is somewhat limited and does not include the particular size I was looking for (1 x 1 x.125 with round corners).  I think I will grunt through the regular way of modeling this frame.
Thanks for the help.  It would be a desirable feature to have this Miter command be applicable to other shapes other that those generated through the Frame Generator.
blair
Copy this file into your directory: C:\ProgramData\Autodesk\Inventor 2015\Content Center\Libraries
Then add it to your Project and then Migrate it. It will have some smaller HSS members
Delta Tau Chi ΔΤΧ
