Inventor General Discussion
Distinguished Contributor
1 Kudo
Post 1 of 7
How do you word wrap leader text?
783 Views, 6 Replies
04-16-2012 09:46 AM
very simple,
Enter key.... carraige return.  Will push text to the next line.  Works like any other text editor.
Hi Vitornis,
I think you need to create a sketch, sketched symbol, or something similar and use the Text tool within that environment before you can use the Text Box option. For some reason the standard drawing text tool and leader text tools both lack the ability to define a text box.
Within a sketch you can use the Text Box button in the text editor, or right-click on the text and choose Text Box. Then you can define the length of the text box with a dimension or just click and drag a corner to eyeball it.
If you have this need often, it's probably worth creating a sketched symbol to use, and just include a leader when placing it.
Adding the Text Box option to the standard drawing text tool  would probably make a good feedback request:
http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
I hope this helps.
Curtis
843 Kudos
Post 2 of 7
Re: How do you word wrap leader text?
04-16-2012 10:03 AM in reply to: Vitornis
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
1 Kudo
Post 3 of 7
04-16-2012 10:09 AM in reply to: Vitornis
Well I meant something more intuitive like word wrap for you based on a certain text box width. Espically for text that is link to a property from my model. Hell any other text editor will autowrap for you when you get to the edge of the page.
6 Kudos
Post 4 of 7
04-16-2012 12:17 PM in reply to: Vitornis
Replying in case someone else has a good answer . . .  (I don't . . .)
1,702 Kudos
Post 5 of 7
04-16-2012 12:45 PM in reply to: Vitornis
Hi Vitornis,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
6 Kudos
Post 6 of 7
04-16-2012 02:13 PM in reply to: Curtis_Waguespack
This helped me Curtis. Thank you for contributing.
1 Kudo
Post 7 of 7
04-16-2012 02:31 PM in reply to: Vitornis
Ooo never really thought about using a sketch symbol. Can't wait to try this thanks for the suggestion!
