Inventor General Discussion
*Pro
Dennis_Jeffrey
Message 11 of 27 (525 Views)
Re: How do you turn off visibility or suppress welds for use in drawing views
06-14-2010 06:49 AM in reply to: jweiss
It helps to put that in your signature for future use.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
**Master
BMiller63
Message 12 of 27 (516 Views)
06-14-2010 07:26 AM in reply to: Dennis_Jeffrey
I'd like to change my previous answer from what I said (use a subassembly), to what Dennis said (use a view rep)! :smileyhappy:
Actually both would work, but Dennis' solution is the better choice.
Valued Mentor
jweiss
Message 13 of 27 (507 Views)
06-14-2010 08:24 AM in reply to: Dennis_Jeffrey
Hi Dennis,
I followed your instructions and created the LOD and design rep and all the parts suppress and un-suppress properly.  When I suppress the welds in my new LOD they stay suppress is all LOD's including the master.  The welds do not reactive to different LOD's like the components do.
Please try your process on my dataset and let me know if you see the same thing as I do.  I want to see all welds in all views except the sub-assy view in the middle of sheet 2.
John Weiss
CAD Admin
Follett Corp
Inventor Pro 2010
John C Weiss Jr.
CAD Administrator
Follett Corporation
*Pro
Dennis_Jeffrey
Message 14 of 27 (501 Views)
06-14-2010 09:00 AM in reply to: jweiss
I did it without issue in 2011, however, it should work the same way in 2010. See attachment.
I'll be out of the office for most of the day, but if you cannot get it to work, let me know and I'll redo in Inventor 2010 or contact you.
Valued Mentor
jweiss
Message 15 of 27 (486 Views)
06-14-2010 10:36 AM in reply to: Dennis_Jeffrey
Hi Dennis,
I just tried again and the welds are not being controlled by the LOD.  I've followed you instructions twice and either the welds are suppressed in all LOD's or they are on.  It doesn't seem like LOD can control the weld suppression in Invento 2010.
If you can try this in INV2010 I would really appreciate it.  I'm pretty good at Inventor and this does not seem to work.
John Weiss
CAD Administrator
Follett Corp
Inventor Pro 2010
John C Weiss Jr.
CAD Administrator
Follett Corporation
**Master
BMiller63
Message 16 of 27 (478 Views)
06-14-2010 11:15 AM in reply to: jweiss
Hi guys,
Okay I'm gonna waffle on this again (maybe I'll go into politics soon!).
I looks like when I ran through Dennis' steps this morning, I didn't update the drawing views and therefore didn't catch that the weld reapeared in the view when unsuppressed.But I just ran though it again and sure enough it's an all or nothing thing.
So, I'm back to my earlier recomendation of using a subassembly for the 3 parts (00958421, 00102137, 00958413) for the first step. If the concern is that the subassembly will list in the BOM, just be sure to set the subassembly as Phantom. Weld beads 1 and 14 will need to be removed from the top level assembly and placed in the sub.
And then the view on sheet 2 needs to be set to 'Assembly' in the Model State area, this will show the top level assembly as it existed before the second series of welds were created.
I did this all in Inventor 2010
Okay, that's my stand on this for now (until Dennis comes back and shows us a better way!)
I'm Bmiller63 and I approve this message.
Valued Mentor
jweiss
Message 17 of 27 (473 Views)
06-14-2010 11:20 AM in reply to: BMiller63
I have to agree with you.  I've tried your workflow and everthing worked great.  I was hoping that I would be able to do it without having to create a sub-assembly and use LOD like Dennis suggested.  I would be really curious to see if this is an improvement to INV2011.
Thanks for all your help!
John Weiss
John C Weiss Jr.
CAD Administrator
Follett Corporation
*Pro
Dennis_Jeffrey
Message 18 of 27 (454 Views)
06-14-2010 05:02 PM in reply to: BMiller63
It worked in 2011. You can see selected welds in the attachment. I'll try it again in 2010 when I get a chance.  Tell me which welds (by name) you want to preserve.
*Pro
Dennis_Jeffrey
Message 19 of 27 (452 Views)
06-14-2010 05:36 PM in reply to: jweiss
Just redid th eexercise in Inventor 2010 SP3. Same result. I can supress/unsupress welds at will.  Here's the 2010 result.
Sheet 2 View 16.
**Master
BMiller63
Message 20 of 27 (446 Views)
06-14-2010 05:50 PM in reply to: Dennis_Jeffrey
but can you show welds 1 and 14 only on sheet 2 and then show all of the welds on sheet 3?
Sheet2 being weld stage 1 and sheet3 being weld stage 2.
It seems that you can either have welds suppressed or not have them suppresed there is no way to represent the same weldment in two different views at two different stages. The view rep does not hold the weld supression state when toggled back on/off.
