Inventor Forum
How do YOU show grain direction?
4 REPLIES 4
chad38
7614 Views, 4 Replies
So, from time to time we need to show the direction of the grain on sheet metal parts. In order to do this I've been clicking on the view, creating a new sketch, then I've been drawing little dotted lines on a mostly blank area, constraining them(in case the part changes so they will stay attached) then I back out of the sketch, using a dimension style I set up for ordinate dims that has lettering vertical I run a dim from the endpoint of one dotted line to the endpoint of the other, and I place it with the arrows covering up the dotted lines, then I double click the dimension, check the box for hide dimension value, and type in "GRAIN". I've just been feeling like there's probably a way to do this where I don't have to do all these steps. How would YOU do it?
example:
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
4 REPLIES 4
stephengibson76
in reply to: chad38
a sketched symbol
Stephen Gibson
View stephen gibson's profile on LinkedIn
blair
in reply to: stephengibson76
We just use a simple note, text with arrow. As with the previous post answer a symbol is great as well. (just to lazy to create a symbol)
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
chad38
Okay guys, thanks, now how do I create a sketched symbol. I assume once created it would show up with other symbols like weld and datum, but I'm making sketches and cannot figure out how to save out as a symbol.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
blair
in reply to: chad38
From the Inventor Help File: http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-EF6BFD15-804A-4A9B-A002-C75B61ED6E75
Delta Tau Chi ΔΤΧ
