I am using thread appearance on both these parts.How would you create the threads on both parts like real world threads.When assembled they then look natural like real world
Parts 2014
Thanks for any help
Damian
Solved by JDMather. Go to Solution.
Solved by mdavis22569. Go to Solution.
Use the Coil command to cut them - just like the real world.
But you used the wrong size hole for a 16mm thread - use the tap drill size - you have no material for thread engagement.
The CADWhisperer YouTube Channel
I tried the coil command which gives a thread but how to i fix as it is not correct.I started with this part before the nut
Where did i go wrong?
Have you ever cut a thread on a lathe?
The cutting tool must start off of the part before entering the part.
What thread designation are you using? (what book or website)
Your thread does not appear to be a standard angle to me?
Do you want a left hand thread or a right hand thread?
Damian
You do need to make sure you are using the right thread shape/angle like JDMathers was saying ... and
Just start your first thread above the solid that you want to show threads on to show it all of the way.
I noticed the stock sized are odd too ..you have 15.7 and 9.65. You should have your stock set up for the right thread you want too.
Just a note, becareful on memory comsumption ...that's why a lot of people stop putting the cuts in and just use the show threads in the 2d
Thanks Michael
Would you have a 2014 version of the file you attached
Yes it should have been 10mm and 16mm.....i deleted some features of the part and did not re-check
Thanks again
Damian
I only adjusted the bottom one ...
also
http://www.engineersedge.com/hardware/metric-external-thread-sizes1.htm
I adjusted the pitch to 2. Changed the OD to Ø16,0 mm
Be sure to post your final result file.
Are you going to 3D print these parts?
I changed the smaller thread.How do you finish off the thread ends....is this with another coil?
If this is correct do i just do the same to the nut?
What book or url reference are you using for the threadform?
I think you probably need to change that 90° to 60°.
Also, isn't a thread specification normally given in terms of Pitch?
I would Chamfer before the Coil.
Add a 1/4 turn 60°Taper Coil to finish off the thread to make it look realistic.
Maybe something like this is what you are after.
http://en.wikipedia.org/wiki/Screw_thread#Form
