Inventor Forum
how do you make active constraints in sub assemblies
2 REPLIES 2
davecooper
339 Views, 2 Replies
Hello All
Does anyone know how you can keep constraints active in sub assemblies so that when I am moving a subassembly the extra movement say in a transitional constraint is able to move so I can see if the total movement allowed is to much?
Thank you for your support Dave Cooper
2 REPLIES 2
Mark_Wigan
in reply to: davecooper
hi dave,
not 100% sure I understand what you need but ...
ensure that the relevant parts located in your sub assembly are free to move in the manner that you require them to move when you are dragging the sub assembly around in the parent assembly.
then save and close the sub assembly.
from within the parent assembly, make that sub assembly to be "flexible". so that way, as you move the sub assembly around, anything that impacts the position of those parts will cause them to move according to the constraints that you have previously defined.
there is an article here if it helps:
http://wikihelp.autodesk.com/Inventor/enu/2014/Help/1283-Inventor1283/2454-Assembli2454/2722-Represe...
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
davecooper
in reply to: Mark_Wigan
Thank you Mark
Problem solved.
Regards Dave Cooper
