I'm trying to place some pictures (.jpeg, bitmap, whatever) onto an inventor drawing but it won't let me. I see when you create a sketch in a drawing there is an "image" option in the insert tab, however this option is always grayed out for me no matter what I try.
The way I insert pictures on a drawing now is just to create a part, put the image as a decal on that part and create a view in a drawing with a shaded view. However with this option the lighting shows up and kills the image quality and it seems too complicated to be the correct way. I figure there has to be a simpler method and I'm just missing it.
Thanks.
Solved by mcgyvr. Go to Solution.
You are talking about 2 different things here..
To insert an image into a drawing simply go to the Manage tab and Click the "insert object" button on the insert section.
Then click create from file and browse to your image..
As far as the decal reflection
You can also place images in Sketched Symbols.
Thanks for the help. My main issue was trying to get an image to display on a drawing. The reflection was the problem with my old methodology of viewing an image but now that is now a non-issue for me with the "inset object"
Autodesk should really do something to make it clearer on inserting an image into a drawing. They have "image" under the insert tab which is always grayed out for me. (Why put it in there if it is never an option that can be used?) The way they tell you to do it in the help files does not work in the sketch mode drawing environment. And the way they define "Insert object" as to be used for word files and spreadsheets, not an image.
I agree on that, the icons are greyet out by me as well = the tutorials dos'nt work. Does anyone know wy the icons are greyed out????
Provide the url to the tutorial step where you are having difficulty.
@William1337 wrote:I agree on that, the icons are greyet out by me as well = the tutorials dos'nt work. Does anyone know wy the icons are greyed out????
That "Insert Image" button only works when editing the definition of a title block or symbol. If you're placing the image directly on the drawing sheet, you'll need to use Insert Object.
Why they can't make the same button work for both is something I don't think I'll ever understand.
This was exactly what I wanted to know. Thanks for the solution.
JRY_OlympicHS
You may not add if you are not in the "Define New Title Block" environment.
Click on "Drawing Resources" on the browser, and then right click on Title Blocks and finally left click on "Define New Title Block". Now you should be able to insert any picture format.
Thanks jtylerbc
Yours is the actual solution.
Hi! I thought the instructions provided by the experts are pretty clear. Could you elaborate what exact process you are looking for?
Many thanks!
There have been statements about how to actually get the image into the IDW, but once that is done, there is not ability to rotate nor resize it.
Maybe it can be done in the Sketched Symbols (as jdmather points to). ? ? ?
Hi! Yes, if you insert the image as an object to the drawing, it cannot be rotated. You can only scale it or move it around. You need to create a sketch symbol so that the image symbol can be rotated. Here are the steps to define a new symbol.
1) Go to Annotate tab -> click on the expandable button "Insert Sketch Symbol" -> Define New Symbol/
2) Insert the image to the symbol sketch -> Finish Sketch.
3) Insert the image symbol.
4) Right-click (or double-click) on the inserted symbol -> uncheck Static -> Ok.
5) Drag the rotate manipulator in the symbol to rotate.
Many thanks!
Why can't you just insert an image as you are in sketch mode in a drawing view? The icon is greyed out.
Always 20 steps to solve a simple problem...
Hi! I am sorry I am not sure. There are ways to insert an image to a drawing sheet. You can go to Manage -> Insert Object. It does not have to be a sketch.
Many thanks!
The "insert object" and "insert image" are technically two very different things.
First one is using ObjectLinking&Embedding system function, what means that displaying and editing of an object is delegated to an another non-inventor application. This means that the displayability and visual effects do depend on the set of applications present in system. On the other hand when an image is inserted directly this is up to Inventor to handle the entire displaying chain and the Inventor is the only required component to display an image.
Using objects may then create serious problems when information must be archived.
I would be glad to be able to just insert an image and be sure that it is handled internally by an Inventor.
It's 2022 an inserting an image in an Inventor drawing it is still NOT intuitive.
As this is not something I do often, I find myself looking for help every time...
Yes Insert Image
type the file location example C:\Users\CADAPP\Pictures\
Then Click Browse
Find the Pic click OPEN
Enjoy
