Inventor Forum
How do you handle sending ‘electronic’ files to suppliers?
7 REPLIES 7
Message 1 of 8
markc-uk
1553 Views, 7 Replies
All,
Hope you’re having a good weekend. I know it’s not really the best place to ask this question but it’s sort of related to Inventor so I’ll fire away;-)
We use Inventor 2012 to model parts and assemblies then create .idw files to produce a paper hard copy, wet signed manufacturing drawing. This paper drawing is our ‘master’ data. The signed drawing is then scanned full size and the resultant .pdf is added into our ERP system and then eventually released to everyone outside of Engineering.
The CAD side of things is not integrated with the ERP system and so we use Vault to control our electronic files.
More and more nowadays our suppliers are requesting our Purchasing department if they can send a .dwg or .dxf, to accompany the signed, scanned .pdf. This I have no problem with, as each drawing is clearly marked with its revision. For this, we burn the requested files onto 2 CDs and keep 1 CD in the drawing office. This is then logged in an excel spreadsheet so we can record the supplier, date, drawings requested and their issue. It’s laborious and a bit long winded but very unambiguous.
What I am more concerned about is the requests we are getting for model data i.e. .stp files usually for a casting or suchlike. These are more difficult to control as they are not marked or identified with any revision.
Do many of you guys/gals on here send model files out to suppliers? If yes, how are you documenting and controlling the revision of model that is sent out to them?
Also, if you have any suggestions for simplifying how we send .dxf drawings out it would be appreciated.
Look forward to some useful information.
MarkC
7 REPLIES 7
Message 2 of 8
DVDM
in reply to: markc-uk
We put a standard note on the drawing, stating that the part is to be manufactured using a DXF file that has the same revision as the drawing.
We send out a DXF file named after the drawing number and revision, i.e.: DRAWINGNUMBERrev2.DXF
Message 3 of 8
markc-uk
in reply to: DVDM
Thanks for the reply DVDM.
Does anyone else care to add their 2 pence worth?!
Message 4 of 8
swalton
We don't send out native files, only dxf, dwg, pdf, or stps.  Our standard note on our print says that the stp file controls the geometry and that the 2d print is for tolerances and reference only.
We had our reseller write a program that generates the 2d and 3d files when a drawing is complete.  They are named PART NUMBERrREVISON NUMBER.FILE EXTENSION.  The program stores these files in vault.  We use a 2nd program that takes an assembly file and collects all the required component files (2d and 3d) into a single zipped archive.  That is emailed to the various vendors for bid.
Steve Walton
Inventor 2023
Vault Professional 2023
Message 5 of 8
For us we need a confidential agreement in place in order for a supplier to see our information even if its a PDF of the drawing.   For a supplied to get the actual CAD file, they have to sign a separate agreement to indicated what is the purpose behind this request.   Also in our Company we take extra steps (granted its a pain sometimes) to protect our Intellectual Property (IP) and to adhere to US Gov Export/ITAR laws.   As I hear more about US export restrictions from our internal expert, the more I wonder what other US Companies are doing to adhere to these rules.   So word of advice..  If your information is leaving US Borders, even if you didn't do it...  I would start investigating to make sure you are okay.   Sorry a little off topic...
So to answer your question...   We convert our Inventor models over to DWG format and provide that information.   If they need a true solid model, then we convert to IGES, SAT, or STEP format..   But we never send the actual model structure to them.
Message 6 of 8
markc-uk
Interesting thought Lancasterm. We too have to adhere to ITAR regs and have to be very careful and mindful of 'technology transfer'.
How do record what models, and what revisions have been sent to what suppliers? Do you simply record it in a spreadsheet or something? Or do you burn the file onto a disc like we do?
Thanks for the input.
MarkC
Message 7 of 8
For us..  Everything is handle through our Contract Admin (CA)/purchasing groups and the information is transferred based on the contract/end-user requirements.   So the CA's manage all of the transmittals or work with the assigned purchasing individual.
But In most cases, we send electronically through our Streamline (Buzzsaw) site and the site does the management of revisions and etc for us.
Message 8 of 8
I've worked for two different companys that approached this problem very differently. In the first we refused to give anyone models, often time prints that were given to suplliers were incomplete or even slightly wrong and then we finished parts in house.The suppliers that did have our intelectual property were all under strict contract as were those of us in the engineering department.
My current company actually sends new prints or step files with each PO. In my department I work closely with just a few suplliers so I send them updated prints/files as we have new revisions come out but for everyone else when the PO goes out the purchasing people pull the print and or model off of our server and send it new each time. This leaves the responcibility on us to make sure the stuff on the server is the most up to date. Our internal database does include rev level listings as well but with us just instituting a new program those details aren't relaible yet.
