Inventor General Discussion
Distinguished Mentor
pcrawley
Message 1 of 6 (1,266 Views)
How do you change the browser node name in a drawing?
1266 Views, 5 Replies
05-18-2013 01:40 PM
Can anyone point me in the right direction for a line of Inventor 2013 iLogic that can change the browser node name of an IDW please?
Specifically, I'm only interested in changing this:
I know how it's set by default, but someone has managed to fix their template so it only ever shows "A3 template" in this field.  consequently, this problem now persists throughout hundreds of drawings. If I can fix it with a line of  iLogic, then the wickedly awesome CodeInjector can be used for fixing all the drawings.
Thanks in advance.
Peter
Peter
if its typed in it will stay until it is cleared. (eg to do this manually for a single drawing, two slow left clicks on the node, to highlight the text, then delete the text and hit enter)
the following is a macro i use for the API, not iLogic.
 Some clues from this may begin to help though ?
Public Sub Clear_DisplayName()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Debug.Print "Displayname = " & oDoc.DisplayName
oDoc.DisplayName = ""
oDoc.Update
End Sub
Mark_Wigan
Message 2 of 6 (1,251 Views)
Re: How do you change the browser node name in a drawing?
05-19-2013 12:22 AM in reply to: pcrawley
oDoc.Update
End Sub
best regards,
- Mark
(Kudo or Tag if Solved - it may help others)
PDSU 2015 Windows 8.1, 64bit.
pcrawley
Message 3 of 6 (1,222 Views)
05-19-2013 02:35 PM in reply to: Mark_Wigan
Perfect - thanks Mark.
Just in case anyone else is looking for this, here's the equivalent iLogic that sets the display name = iProperty Part Number (which it should be by default!):
MessageBox.Show("Displayname = " & oDoc.DisplayName, "iLogic")
'Set display name = iProperty "Part Number"
oDoc.DisplayName = iProperties.Value("Project", "Part Number")
Peter
ankersen
Message 4 of 6 (1,171 Views)
05-30-2013 06:23 AM in reply to: pcrawley
I have this problem on a few drawings.  How can I reset back to the default manually?
When I do as stated above, (highlight & delete) it does not default back to the org. Drawing file name.
The image attached shows the file name test3.idw, but the node is test1.  I need to make the node read test3.idw.
Curtis_Waguespack
Message 5 of 6 (1,155 Views)
05-30-2013 07:05 AM in reply to: ankersen
Hi ankersen,
In a drawing, if you replace the name with a space using the space bar, it should reset fo you. In parts and assemblies, delete the name resets it.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
ankersen
Message 6 of 6 (1,135 Views)
05-31-2013 05:50 AM in reply to: Curtis_Waguespack
it was the space that I needed. Thank you.
