Inventor Forum
How do I tell What Layer a Line is On.
3 REPLIES 3
1603 Views, 3 Replies
When I edit a title block I would like to know which layer a particular line is on.  If I right click to activare the "Properties" dialog box.  All it tells ne is that the line is "By Layer".  How can I tell which layer an entity is on?
Thanks!
Michael Crump
3 REPLIES 3
Curtis_Waguespack
Hi mcrump28210,
Select the line(s) and then switch to the Annotate tab, and look for the Format panel. You'll see the layer drop down box listing the current layer. You can use the drop down to change the layer if needed.
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Thanks Curtis!  BTW, I have all of your books and they have been of tremendous help to me.  Thanks Again!!
Curtis,
Is there a way to create a titleblock in Autocad and use it as the basis for an inventor titleblock without creating extra layers.  BTW, as a SC native, born and bred, GO GAMECOCKS!
Mike
