You're right, it doesn't stick. I'm sure in IV7, if you created a new sheet
format using a sheet with views and 'show tangent edges' checked, the
settings would be carried into any sheet using that sheet format as a base.
Perhaps someone with IV7 could check this?
BTW I'm using IV10 with sp1 installed
Derek
wrote in message news:4897485@discussion.autodesk.com...
How can you set 'show tangent edges' in an (empty) idw.template?
BJ
