I would like to get rid of the following problem:
1) Create a new assembly
2) Place the component Part1
3) Delete the component jast inserted (now Part1 is not used)
4) Create a new part
5) Save as Part1 -> it says "cannot give a document the same name as an open document (or a document that is referenced by an open document, e.g. a part/assembly referenced by a drawing). Enter a different name for the document you owant to save."
This is a simplified sequence. My real application is a VBA macro that does something similar. The first time works, the second time gets stuck because it remembers the component just deleted.
Stefano
Solved by StefanoMenci. Go to Solution.
Close and re-start Inventor is the only way I have been able to solve this issue
