how do i place the hole on a 45° angle and then pattern
Message 1 of 9
Hi
How do i place the hole on a 45° angle and then pattern 15 holes following the 3D Sketch 2 ?
Greg
Replies (8)
Message 2 of 9
Paul-Mason
One method is in the attached ipt file
15 holes seems a bit strange, just means that you cant create 4 holes mirror to get 8 and then mirror again to compete the holes
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
Message 3 of 9
admaiora
Ops, already a solution
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 4 of 9
ravikmb5
i would recommend to use hole Feature
on Point Method
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Message 5 of 9
Paul-Mason
Greg
Why in sketch 5 are there 20 ponts for the holes? But you ask about 15 holes, I'm just a bit puzzled that's all.
 It's alot simpler to create a set of even numbered holes on this type of flange
 I also tried a different methord, to the one in the answer that I first gave, as well as the rectangular pattern, as can be seen in the attached I got some holes in slightly differnent position with the two metehords
Inventor 2026 Pro
Xeon
Message 6 of 9
Thanks for the help. In regards with the holes you correct but i am still playing around trying to learn the way to get the holes at the angle and witht he quickest method
I will see if i can get the rectangle to work
I appreciated the help and you guys knowledge
Message 7 of 9
ravikmb5
Here is the Link to video
File attached for you Reference
https://www.dropbox.com/s/pe0c7ru96b8wvmi/Holes%20on%20Point.mp4?dl=0
Ravi Kumar MB,
Message 8 of 9
ravikmb5
youtube Link
https://www.youtube.com/watch?v=kQDSXphn6_o&list=UUa_ZUgP5X_5Mi1exjHPiI8A
Ravi Kumar MB,
Message 9 of 9
Thanks Ravi for excellent explanation and demo. Thank you
