Inventor General Discussion
annelieselawrence
Message 1 of 28 (1,119 Views)
How do I move objects?
1119 Views, 27 Replies
03-29-2007 11:09 AM
I am creating a machine which is attached and I wanted to put these three pieces together and weld them together so they are one piece. I need the two arcs on either side of the nearly fully enclosed semi-circle. I actually don't even know how to move any objects that are already placed somewhere. Any ideas? Thanks!
*Dennis Jeffrey
Message 2 of 28 (1,119 Views)
Re: How do I move objects?
03-29-2007 11:17 AM in reply to: annelieselawrence
Please place your parts into a zip file before attaching... thanks.
Dennis Jeffrey, AICE, MICE
260-312-6188
Instructor/Author/Sr. App Engr.
Inventor 11 Professional SP2
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
wrote in message news:5535235@discussion.autodesk.com...
annelieselawrence
Message 3 of 28 (1,119 Views)
03-29-2007 11:24 AM in reply to: annelieselawrence
I zipped the inventor file for you as requested.
*Expert Elite*
JDMather
Message 4 of 28 (1,119 Views)
03-29-2007 12:01 PM in reply to: annelieselawrence
How much training did you get? Those are three separate parts should be three separate files. I would save 2 additional times and then delete the extra parts from each of the 3 files. Then I would create an assembly weldment file. Just like the real world.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
annelieselawrence
Message 5 of 28 (1,119 Views)
03-29-2007 12:36 PM in reply to: annelieselawrence
Well, then one more question...I put them on a weldment file but then how do I attach them to each other. I am very new at Inventor. I have worked with AutoCad. I am still a student.
andrewiv
Message 6 of 28 (1,119 Views)
03-29-2007 12:40 PM in reply to: annelieselawrence
You really should go through some training or at least run through the tutorials before trying to use inventor. Look for contraints under the help file and it should answer your question.
Inventor Professional 2014 SP2
Vault Professional 2014 SP1
Windows 7 64 bit
*Gary R Smith \(Autodesk\)
Message 7 of 28 (1,119 Views)
03-29-2007 12:46 PM in reply to: annelieselawrence
You might find that the tutorials that are shipped with Inventor answer
many, many questions.
A weldment is similar to a "normal" assembly: you place component parts
"into" the weldment and you constraint them into their final positions.
Weldments then provide you with the ability to apply: weld preparations,
weld beads and post-weld machining features.
*Expert Elite*
JDMather
Message 8 of 28 (1,119 Views)
03-29-2007 01:02 PM in reply to: annelieselawrence
With assembly constraints.
Work with it a bit and if you can't figure it out hollar back and I will provide an example.
BTW students can get Autodesk Inventor Professional for free from http://engineersrule.org
This doen't address your immediate problem but you might want to go through this document before you develop too many bad habits.
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
*Expert Elite*
JDMather
Message 9 of 28 (1,119 Views)
03-29-2007 01:08 PM in reply to: annelieselawrence
Just out of curiosity - since I'm in the business - doesn't that imply that you are getting some level of professional instruction for which either you or the taxpayers are paying for? Or are you teaching yourself? I ask because it seems to me that a lot of students are doing the later because for some reason they don't seem to be getting what they are paying for.
Distinguished Contributor
Josh_Petitt
Message 10 of 28 (1,119 Views)
03-29-2007 01:51 PM in reply to: annelieselawrence
JD, just an opinion from a former engineering student. The institution where I graduated had a good policy (IMHO). They would not teach ANY software package used by any of the courses. However, all software used by any class was available in the computer labs. The rationale behind this was that software packages change very, very quickly. However, engineering fundamentals do not change as quickly (especially for undergrads). So, with limited hours in a classroom, they concentrated on teaching the fundamentals and it was the students' responsibility to learn to use software XYZ to get the results they needed.
Post to the Community
New Post
Need installation help?
