Inventor General Discussion
Member
dustinr91
Message 1 of 2 (484 Views)
how do I link Inventor .ipt data with .dwg in autocad
484 Views, 1 Replies
10-04-2012 12:21 PM
Hi Everyone,
                     I understand how to link a 3D.dwg with a 2D.dwg, but what I'm having trouble with now is linking the data,
is there anyway to create a table and link data directly from the .ipt to the .dwg that would update when I edited or revised the .ipt. I know that you can do this by exporting the parameters in an excel file then importing them to the .dwg but once I do that there isn't anyway to auto update the data.... I'm not sure that this made a lot of since, but I’ve done everything I can think of to get this to work and I’m stumped. If you have any suggestions or know how to do this I would owe you big
         Dustin P.
You can pull parameters into a text box by parameter name.
This will show the parameter value and update as the model updates.
Have a look at the help below
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0611-Drawings611/0633-Drawing_633/0643-Text_in_643#references
+ Format text
   + Model, Drawing, and Custom Properties
       Add Text Parameter
   + Parameters
       Add parameter
harco
Message 2 of 2 (477 Views)
Re: how do I link Inventor .ipt data with .dwg in autocad
10-04-2012 01:36 PM in reply to: dustinr91
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0611-Drawings611/0633-Drawing_63...
+ Format text
       Add Text Parameter
   + Parameters
       Add parameter
