Hi
Without going too deep into sheetmetal, this is the quick method.
You need to convert it to a sheetmetal part.
Set the plate thickness to the "Plate thickness" Use the measure tool if needed (0.0625in)
Select a face, Click on Create flat pattern.
See attached part.
Reg
2025.1.1
Please Accept as a solution / Kudos
