I'm new to IV VBA and so far I'm finding the help to be no help at all. I need to take an assembly and export each part in that assy as an iges. The examples I've seen are way over my head and when I try to break down each element w/ the help or internet I get squat. ie. TranslatorAddin, no answers in the help files and internet searches bring up all sorts of code. One item is .SaveCopyAs(...,...,...,...). I can't seem to even find a help command that lays out what is needed to use this. Only through searching in other's code can I find the variable types needed but then I hit a wall trying to understand the variable types.
Can someone help me get started?
Is the help for IV somewhere in a .pdf so I can do better searches?
Solved by Curtis_Waguespack. Go to Solution.
To further clarify, I look in the help for transientobjects. Nothing. I can however find something using F1 however I get this description.
"Gets the object through which all general transient objects are created."
In other words, kruxeldefific is definded as: something that is kruxeldefif like.
Hi jpblower,
Here is a quick iLogic rule that will create an *.igs file for each part file it finds in the assembly. Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
'Define the open document Dim openDoc As Document openDoc = ThisDoc.Document 'define folder to create files in oFolder = "C:\Temp\IGS Files" 'Check for the destination folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Look at all of the files referenced in the open document Dim docFile As Document For Each docFile In openDoc.AllReferencedDocuments 'format file name Dim FNamePos As Long 'postion of last back slash FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String 'file name with extension docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) 'file name without extension shortname = Left(docFName, Len(docFName) -4) ' Get the IGES translator Add-In. Dim oIGESTranslator As TranslatorAddIn oIGESTranslator = ThisApplication.ApplicationAddIns.ItemById _ ("{90AF7F44-0C01-11D5-8E83-0010B541CD80}") Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap If oIGESTranslator.HasSaveCopyAsOptions(docFile, oContext, oOptions) Then ' Set geometry type for wireframe. ' 0 = Surfaces, 1 = Solids, 2 = Wireframe 'oOptions.Value("GeometryType") = 1 ' To set other translator values: ' oOptions.Value("SolidFaceType") = n ' 0 = NURBS, 1 = Analytic ' oOptions.Value("SurfaceType") = n ' 0 = 143(Bounded), 1 = 144(Trimmed) oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oData As DataMedium oData = ThisApplication.TransientObjects.CreateDataMedium 'set file path for IGS file oData.FileName = oFolder & "\" & shortname & ".igs" oIGESTranslator.SaveCopyAs(docFile, oContext, oOptions, oData) End If Next
Thanks,however my issue is less the code itself rather how to identify the elements within.
Ie. the IGES translator ID is ("{90AF7F44-0C01-11D5-8E83-0010B541CD80}"). If not for copying from this forum or another file how on earth would I ever be able to find that number?
In the nameValueMap options values for a *.pdf and I want to set the option "Sheets in Range>From" I need to write ' *.Value("Custom_Begin_Sheet"). How do I find out that "Custom_Begin_Sheet" is the value for that particular option? If I didn't already know the value needed I can't find any way to discover that other than searching through tons of internet code praying someone used the options I need.
This example is the best I've been able to find but rather cumbersome just to find an option value.
Hi jpblower,
I would start with the Programming Help pages and lookup TranslatorAddIn for example, then dig through the TranslatorAddIn Members.
There are some more link to look at here:
http://inventortrenches.blogspot.com/2013/10/ilogic-how-to-learn-inventors.html
I hope this helps.
Curtis
Thanks, i was looking in areas of help which would never point me in the right direction. When searching under Translator Addins I gets me the information I was looking for, as opposed to looking in the values property for NameValueMap. While this is horribly frustrating starting out it does help me see the mindset of the help.
