Ok, so I have two suggestions.
1. You should NEVER dimension a hole in any
view except one that the hole centerline is perpindicular to the view.
This is basic drafting standards.
2. If that is not possible then you should
still be able to creat a dimension to the center of the hole (ellipse) by
hoovering over the center of the hole until a green dot appears and select it to
dimension to then pick the end of the rod and place the
dimension.
