I am trying to create a loft to shaped a back cushion and then send the loft to all parts. But I do not see Loft as an option under assembly level. What am I missing?
Solved by JDMather. Go to Solution.
You will need to use multi-body solids techniques
or
Copy Object from on part in assembly
or
Derived Components.
Attach your assembly here if you can't figure it out.
I would probably do as multi-body solids master file and then Manage>Make Components to derive the individual parts.
That is the easiest solution.
Hi there. Good morning. Well I created the Multi body part. I attached the file, because I was unsuccessful in making the cuts I need. When you open the attachment you will see my side profile sketch/ cut I need to make as well as the 2 loft sketches to create the final cut of the back cushion. For some reason creating the lofted cut on the multibody did not take for me. Im looking forward to hearing your reply. Thank you for your time.
I got it 🙂 I didnt realize at first that I needed to create the Loft as a surface then use split to make the cut to each solid. Came out nice (with adding a few rails...) . Thank you for you suggestions. You where a big help.
