Solved by scottmoyse. Go to Solution.
Solved by karthur1. Go to Solution.
Public Sub SetActiveDocUnits()
Dim oActiveDocument As Inventor.Document
Set oActiveDocument = ThisApplication.ActiveDocument
SetLengthUnitsToInch oActiveDocument
End Sub
Private Sub SetLengthUnitsToInch(Document As Inventor.Document)
'Get Units of Measure
Dim oUOM As Inventor.UnitsOfMeasure
Set oUOM = Document.UnitsOfMeasure
'Set length units to inch and save
oUOM.LengthUnits = kInchLengthUnits
document.Dirty = True
Document.Update
Document.Save
'Run recursively for assembly
If TypeOf Document Is Inventor.AssemblyDocument Then
Dim oAssemblyDocument As Inventor.AssemblyDocument
Set oAssemblyDocument = Document
Dim oOccurrence As Inventor.ComponentOccurrence
For Each oOccurrence In oAssemblyDocument.ComponentDefinition.Occurrences
SetLengthUnitsToInch oOccurrence.Definition.Document
Next oOccurrence
End Sub
Just to contribute to this beauty. I've tweaked this to correct the units for the rest of the world 😉
Also changed it from only modifying Length units, but also mass & angle.
Thanks to all in this thread for posting this in the first place. I'll be using this to convert all of the Inventor HSM CAM datasets to metric from imperial.
Public Sub SetActiveDocUnits() Dim oActiveDocument As Inventor.Document Set oActiveDocument = ThisApplication.ActiveDocument SetUnitsToMetric oActiveDocument End Sub Private Sub SetUnitsToMetric(Document As Inventor.Document) 'Get Units of Measure Dim oUOM As Inventor.UnitsOfMeasure Set oUOM = Document.UnitsOfMeasure 'Set length units to Metric and save oUOM.LengthUnits = kMillimeterLengthUnits oUOM.MassUnits = kGramMassUnits oUOM.AngleUnits = kDegreeAngleUnits Document.Dirty = True Document.Update Document.Save 'Run recursively for assembly If TypeOf Document Is Inventor.AssemblyDocument Then Dim oAssemblyDocument As Inventor.AssemblyDocument Set oAssemblyDocument = Document Dim oOccurrence As Inventor.ComponentOccurrence For Each oOccurrence In oAssemblyDocument.ComponentDefinition.Occurrences SetUnitsToMetric oOccurrence.Definition.Document Next oOccurrence End If End Sub
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Good stuff, Scott.
I think, that can be used with imported STEPs or other types for changing angles from radians to degrees, too.
I'll try it instantly.
Walter
Walter Holzwarth
Look here. I think it's the same issue:
Walter Holzwarth
Hello Scott,
Please, can you make a short screencast video which shows how to insert this code in inventor and how this code is used.
I know nothing about this things.
Thank you!
Hi!
Could you please convert this code to ilogic?
Thanks in advance.
Hi Manuel,
The 2023 iLogic debug tool helps quite a bit. I can follow the error message and correct the syntax to VB.Net. Here you go. Just copy the following and paste it to a rule.
Many thanks!
Johnson
Public Sub Main()
SetUnitsToMetric(oActiveDocument)
End Sub
Document.Update
Document.Save
SetUnitsToMetric(oOccurrence.Definition.Document)
Next oOccurrence
End Sub
@johnsonshiue Thanks a lot!
I know it was probably easy to solve, it's my fault not knowing how to program.
Also we aren't yet on 2023.
I'm getting an error when I run it on assemblies, and also in parts when I run it with trigger before save.
Hi Manuel,
No, it is not your fault that you don't program. You don't need to. I am not a developer either. I am just a user happening to know the product relatively well.
If possible, please share the files and the rule with me directly johnson.shiue@autodesk.com. I would like to take a closer look. It is possible the rule has issues that I did not see.
Many thanks!
Hi Folks,
Manuel sent me his files and the rule. I think it was a bit over-complicated. Here is a simpler rule to change the document units. It should work.
Dim oAssy As Document = ThisApplication.ActiveDocument
Dim allDocs As DocumentsEnumerator = oAssy.AllReferencedDocuments
Dim oDoc As Document
For Each oDoc In allDocs
oDoc.UnitsOfMeasure.AngleUnits = UnitsTypeEnum.kDegreeAngleUnits
oDoc.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kMillimeterLengthUnits
oDoc.UnitsOfMeasure.MassUnits = UnitsTypeEnum.kKilogramMassUnits
Next
Many thanks!
@johnsonshiue Perfect!
Is there any possibility to have for example grams in parts and kilograms in assemblies?
Just to note for other people this rule doesn't change the values in the assembly we are running the ilogic, but that's easy to solve.
Thanks a lot Johnson!
Hi Manuel,
Here you go! You need to change the unit enums accordingly. This rule just shows how to change Doc Units per doc type within an assembly.
If oDoc.DocumentType=Inventor.DocumentTypeEnum.kPartDocumentObject Then
oDoc.UnitsOfMeasure.MassUnits = UnitsTypeEnum.kGramMassUnits
Else If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject
oDoc.UnitsOfMeasure.AngleUnits = UnitsTypeEnum.kRadianAngleUnits
oDoc.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kMeterLengthUnits
Next
Many thanks!
