This morning I somehow changed the way the command icons are displayed, so how can I restore the command icons back to the default display. I've tried to figure out where the setting is for the way the icons are displayed, but I haven't been able to reset it back to the default setting.
Here's what the display got changed to, that I want to change back to the default setting.
If you mean that you want the small icons I know in 2012 you can right click on the ribbon and then expand ribbon appearance and then click small, which will give you something like what you showed.
Thanks very much Dan. Thats was it's, and I set the ribbon display back to the normal setting, which is what I'm used to using.
Scott
