Inventor Forum
How do changes the icon display in Inventor Professional 2011
4 REPLIES 4
07bandit
422 Views, 4 Replies
This morning I somehow changed the way the command icons are displayed, so how can I restore the command icons back to the default display. I've tried to figure out where the setting is for the way the icons are displayed, but I haven't been able to reset it back to the default setting.
Here's what the display got changed to, that I want to change back to the default setting.
4 REPLIES 4
schae235
in reply to: 07bandit
Tools>Application Options>Colors
at the bottom of that menu there is a Color Theme.
INV 2012 SP1
Windows 7 64 Bit
ATI FirePro V5800
14.0 GB RAM
schae235
in reply to: schae235
If you mean that you want the small icons I know in 2012 you can right click on the ribbon and then expand ribbon appearance and then click small, which will give you something like what you showed.
INV 2012 SP1
Windows 7 64 Bit
ATI FirePro V5800
14.0 GB RAM
GSE_Dan_A
Right click on Ribbon --> Ribbon Appearance --> Normal (or what ever suits your style)
GSE Consultants Inc.
Windsor, ON. Canada
07bandit
in reply to: GSE_Dan_A
Thanks very much Dan. Thats was it's, and I set the ribbon display back to the normal setting, which is what I'm used to using. Smiley Happy
Scott
